Emergency
Old Dec 23, 2002 | 01:04 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
Emergency
i lost my car keys for my 82 trans am..
The key cutting place said i need a code number for them to make a new key..where do i go to get one???
Old Dec 23, 2002 | 01:21 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You will have to go to your Local GM dealership and see if they can help you. They can use your Original cylinder to make a new key. EIther way your GM service center is probably the only one that can help you right now. HTH
Old Dec 23, 2002 | 01:25 PM
ede's Avatar
ede
unless i'm way off any good lock smith should be able to figure out what you need with a "key gun" or what ever they call it.
Old Dec 23, 2002 | 01:28 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Most lock smiths don't like to do it, due to the fact you may be stealing the car. Here, where I'm from, most of them won't even copy any car key with out seeing the car and the ownership, and ID of course.
Old Dec 23, 2002 | 04:24 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Any GM parts department as the ability to cut a key for you. All they need is a VIN number...as long as none of the locks in the car have been changed.
Old Dec 23, 2002 | 05:05 PM
Vader's Avatar
Ed is dead on. Any good locksmith has access to the same information the dealer has, and they are usually much faster, cheaper, and better quality. Same for VATS keys. Dealers generally get about $27.00 per copy, my local professional locksmith gets $6.00 plus a little something for the governor's retirement/legal defense fund. All they want is proof of ownership, like the registration and your driver's license to verify you didn't steal it. They'll keep records of the activity just in case someone reports it stolen.
EDIT: If you're in a real pinch and have the tools, you can get a replacement cylinder with two new keys. You '82 doesn't have VATS, so a new cylinder is about $12 at AutoZone, Pep Boys, etc.
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jj4
Oct 9, 2000 01:31 PM
