Wheel/Tire Question
Old Dec 25, 2002 | 12:28 PM
thunderChris10's Avatar
Wheel/Tire Question
what are the widest tires i can put on my stock RS wheels?
Old Dec 25, 2002 | 12:33 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can put 235/60-15 front and 255/60-15 rear. i did on my 91 v6.
Old Dec 26, 2002 | 12:44 AM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
You also need to pay attention to what size of tire is allowed on a particular rim. This would be a safety consideration. You can go outside the allowable and people have. But you could blow a tire off the rim just hitting a pot hole if the bead and rim did not have the correct contact surface. The Tire and Rim Association has standards telling what rim a particular tire is designed for, and what an optional rim would be. If you reply what size rims you have, I can check the book and tell you what sizes are allowed on that rim. Some of the tire sizes may not even be manfactured by anyone. But each size of tire is designed for a particular rim width. It does not tell you if that tire will fit the car.
If you have 15x8 rims, then these tires are designed for an 8 inch rim.
265/70r15, 275/70r15, 265/60r15, 275/60r15, 255/55r15.
These are allowed on a 8 inch width rim.
235/75r15, 245/75r15, 265/75r15, 235/70r15, 245/70r15, 255/70r15, 235/65r15, 255/65r15, 295/65r15, 225/60r15, 235/60r15, 245/60r15, 255/60r15, 295/60r15, 225/55r15, 225/50r15, 245/50r15, 265/50r15, 275/50r15, & 295/50r15.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
