cam swap with engine in the car
Old Dec 28, 2002 | 08:44 PM
wyldbillracer's Avatar
How many of you have replaced the cam with the engine in the car? is there room to drop the oil pan enough to get the timeing cover off and on? Thanks.
Old Dec 28, 2002 | 08:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've done it a couple of times, plenty of room, just have to remove some stuff, and bend the front support bars in front the radiator a little.
Also, the oil pan, just take out the front 2 screws that should give you enough access room to put the timing gasket on.
Old Dec 28, 2002 | 10:17 PM
thanks for the info, I have one that needs a new cam and was going to try to install it with the engine in the car.....thanks again
Old Dec 28, 2002 | 11:03 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i removed the front four bolts on each side of the oil pan. then loosened the rest to get the pan to drop down. plenty room.
Old Dec 30, 2002 | 01:02 PM
felo72's Avatar
Be carefull not to nick the cam bearings when taking out the cam. It's pretty tight pulling it out with the engine still in the car. As for the oil pan, I agree with them.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
