Temperature Gauge
Old Dec 29, 2002 | 10:05 PM
Bennyb8323's Avatar
Temperature Gauge
My temperature gauge and instrument cluster is not functional. Can it be fixed or does the whole cluster have to be replaced?
Old Dec 30, 2002 | 11:06 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You mean nothing at all works in the instrument panel? Or just the Temp Gauge?
If just the Temp Gauge, then take a look between and below #1 and #3 spark plugs, you'll find the sensor for your gauge. Make sure the wire connector is secure and intact.
If the whole cluster is not functioning then may just be a fuse.
Then again, if you have a 'Bird with a different type of dash, you may need more help.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
