Oil Pressure Gauge Sender Location
Old Dec 31, 2002 | 12:01 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
What is the best place to put the sender for a mechanical oil pressure gauge? I put mine in the front of the block above the timing chain cover, and I noticed that it is always reading a lower pressure then my stock gauge(sender is right above oil filter). Should I move the sender behind the intake or remove the stock one and put it there?
Also, I have noticed that there is not much oil in the tube that goes to the oil pressure gauge. There is a small amount right next to the block, but by the time the tube gets to the firewall there is little, if any, oil in the line. Is this a problem?
Brady
Old Dec 31, 2002 | 02:03 AM
NTChrist's Avatar
I would say that the oil not building enough pressure to get to the guage would be a problem. Is the line kinked/blocked?
I would recommend going with the stock sender location.
Although, that may not be possible, as the stock sender is a kind of big diameter, and the new one may be smaller. Let us know.
Old Dec 31, 2002 | 05:55 AM
ede's Avatar
ede
i'd use the china wall locatio nand trash the plastic line and use copper.
Old Dec 31, 2002 | 11:22 AM
the line is not kinked or blocked in any way
yes i know i need to ditch the plastic, but do you think the air in the line or the location is giving me a lower reading?
Old Dec 31, 2002 | 12:22 PM
ede's Avatar
ede
no most if not all of them that i've seen had air in the plastic lines
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
