Help!!!! need info on main/rod bearings
Old Jan 2, 2003 | 08:27 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the LT1 uses the same rod/main bearings as a standard sbc correct(L98)? i'm gonna be pulling the bottom end out to replace the crank. gotta put in new bearings right... don't ask long story .
thanks guys
Old Jan 2, 2003 | 10:20 PM
Vader's Avatar
Mystik,
I know the LT1 rod and main journal sizes are the same, but I never checked the shell thickness or bores when I had the '94 apart. I would presume they are the same, but you never know - there are a lot of other differences between the two designs.
Old Jan 3, 2003 | 08:57 AM
Car: 1988 IROC-Z
take a look at this http://www.moreperformanceinc.com/bearings.htm they list the LT1/L98 Main/Rod Bearings as the same part. i will do more searching to verify this. thanks again
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
