two multec injectors wanted
Old Jan 5, 2003 | 03:39 PM
ron88bird's Avatar
HiYaAll,
Finally diagnosed my 88 2.8. Was runnin really crappy, loss of power and running rough. It appears that I have two bad injectors on cylinders 2 and 4. I diag'd by pullin the wires individually, no change on 2 or 4; plenty of spark. I turned over the engine with #2 spark plug pulled and a bunch of fuel sprayed out plus the plug was wet to begin with.
If anybody has a couple of Multec injectors that work and want to sell lemme know. BTW, I replaced my IAC and the problem of it starting for a second then stopping, having to restart the car many times until it finally took, fixed that.
Ron
can be reached at :
RDIEDERICH@DNPS.COM
Old Jan 5, 2003 | 07:38 PM
Vader's Avatar
I've been watching eBay for about a month for a set of 15 pounders for a 3.1. I'm not having a lot of luck, but I've seen a few sets of 2.8 injectors, rails, regulator and all going pretty cheaply.
You probably should post this in the Classified Section.
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
tmellott89
Aug 16, 2015 02:58 PM
