need help, problem getting worse
Old Jan 2, 2003 | 03:31 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
Here it is. When i take off and start to accelerate there is a gurgling or knocking noise coming from the enging bay. It usually makes the noise when im accelerating and only when in gear. If i put it in neutral and rev the engine it sounds good. But when im accelerating it makes a loud almost like a deep gurgling sound. What can this be? Any ideas?
Old Jan 2, 2003 | 04:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Does the sould come from the engine area? Could be timing is too far advanced. Do you have access to a timing light?
Old Jan 2, 2003 | 04:51 PM
ctandc's Avatar
Need a more descriptive sound
"Rocks rattling around in a coffee can" kind of sound?
- Sounds like detonation. Start with checking for over-advanced timing.
To be sure, run some premium or some octane boost and see if it goes away. Shouldn't be detonation if the knock sensor is functioning correctly. Unless the timing is WAY advanced. Is is hard to start?
HTH
Old Jan 2, 2003 | 06:24 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
sounds like its coming from the pass side of engine bay. it really sounds like a deep gurgling sound, you could probably say it sounds like rocks in a coffee can.
engine starts right up. it only makes the noise when the engine is warmed up.
Old Jan 3, 2003 | 05:04 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
ill try the high octane. someone else said it may be pinging. is this caused from timing being too advanced? it only does it when the engine heats up and is under load.
Old Jan 4, 2003 | 12:20 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
my car has made this sound for over a year now, im not to worried about it tho, i beleive it is a bent pushrod, brokedown lifter, or wore out cam lobe,
Kevin
Old Jan 5, 2003 | 12:39 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Well im getting worried because its getting worse. i tried octane boost and that didnt help. i dont think its the timing because it starts right up and runs fine. it just makes this noise and i need to figure out what is causing it before its too late. Anyone out there know what it is?
Old Jan 5, 2003 | 07:17 PM
Vader's Avatar
It could still be timing. The EST will retard timing for start-up (or technically, not advance timing above base). Even at 15° BTDC the engine would start normally.
Old Jan 5, 2003 | 07:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably an exhaust leak. Try tightening up all the hardware around the exhaust manifold on that side.
83 Crossfire TA
Jan 3, 2016 01:26 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
