Possible and common Vacum Leaks.
Old Jan 6, 2003 | 12:11 AM
Joeboy's Avatar
I think I might have a vacum leak. What are the most common spots and even the least common spots for me to check. Its a Carbed 82 305. Thanks in Advance.
Old Jan 6, 2003 | 01:49 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
well i've found the best way to check for a vaccuum leak is to take a can of carb cleaner and start spraying around the carb and any other place around the manifold area. if the engine picks up and runs faster/louder/higher rpm, then u have narrowed your leak and know that u have a leak. i've personally dealt with leaks around the carb gasket on the 68 torino gt 390 2 bbl. the local autoparts store gave us the wrong gasket and didnt seal up to the manifold correctly
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
FormulaEngland
Sep 30, 2015 01:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
