valve stem seals
Old Jan 6, 2003 | 01:36 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
valve stem seals
I plan on using the positive retention seals part# 72527 along with the o-ring style. Can I use the positive retention style on all of the valves, or are they just for the intake side? Also I called Napa and Autozone about the o-rings, they are 59 cents a piece at NAPA and at Autozone they were like $12 for the intake and I think $17 for the exhaust. What is up with that?, that is quite a price difference.
Old Jan 6, 2003 | 01:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can use the positive seals for both intake and exhaust.
Sounds like the prices they gave you are for the positive seals, not O-rings. A full set of O-rings (all 16 would be identical) should be around $2 or $3 max.
The O-rings are pointless if you use real seals, I would not spend any money on them, they don't work.
Old Jan 6, 2003 | 01:52 PM
ede's Avatar
ede
i use both, i figure for a dollar or two what's it going to hurt.
Old Jan 6, 2003 | 10:06 PM
Vader's Avatar
The GM positive seals are different, too. They are identified by a brown or white stripe (white is exhaust IIRC). They are both PTFE seals, but the exhaust seals are designed with lower edge pressure and a higher temperature material.
Old Jan 7, 2003 | 07:40 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
The Autozone prices they quoted me were right, that was for the positive retention seals and they come with the o-rings. The exhaust were more because of the higher temp material the seals are made of as Vader stated.
Old Jan 8, 2003 | 11:39 AM
FJK's Avatar
FJK
Vader:
Do you happen to have the GM p/n's for both the intake & exhaust seals you mentioned? Are these seals retrofitable back to a '88 5.7L engine? Do the top ends of the guides need to be reworked to accomodate these seals? What are your thoughts on running both the o-rings & the positive stem seals?
What is that? 4 questions, not counting the last ones?
FJK
Old Jan 8, 2003 | 01:58 PM
Vader's Avatar
FJK,
Yeah, that's about four. You get sixteen more...
The upper ends of the valve guides would probably have to be machined for the seals, since I believe the L98s did not have that provision.
I don't have the number for the seal kits themselves, since I've acquired them in either the rebuild gasket set or head gasket kit (including a head gasket, valve seals, intake gaskets, rocker cover gaskets, etc.). Your dealer should be able to get you a part number for th eseals alone.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
