Balancer ?
Old Jan 8, 2003 | 06:08 PM
blksc's Avatar
Balancer ?
What type of puller is needed to remove the balancer from the crank ?
Old Jan 8, 2003 | 06:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
why a harmonic balancer puller of coarse Most auto parts stores will sell/ rent pullers so you can go to autozone or some equivelent place and get one. I have a cheapie napa one that i wouldnt recommend for a balancer thats been in place for 10 + years. Really flimsy.
Old Jan 9, 2003 | 12:40 AM
blksc's Avatar
hey im learning
Thanks picked up one today and it worked like a charm
Old Jan 9, 2003 | 05:32 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
and here is how you put it back on...cheap ....per Vader....
That "harmonic balancer installer" consists of a 7/16-20 threaded rod, 5" long or longer, a 7/16-20 nut, a washer, and a large drift (socket or the thick washer from your balancer bolt) to spread the load. If you can't find a dedicated "installer", you can assemble one from those parts, which should be available from any good hardware store.
Don't hammer it on, please. And don't try to use the original bolt to install the hub. I'm not ready for another one of those "Oh, Crap! I stripped my crankshaft!" type threads on the Tech board.
Before installing the balancer, rub some clean petroleum jelly (Vaseline) on the outer hub that will contact the seal so that the new seal doesn't get damaged on installation or from running dry on start up.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
