found out why but what? Internal vacuum leak.
Old Jan 10, 2003 | 01:44 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's that fNord PU I posted a week back about, I finnaly got around to messing with it again. It does have an internal vacuum leak and will suck a finger down into the valve cover. I've eliminted the intake and gaskets as problems now im just left with the head down. I'm thinking valve guides could be shot any other idea's???
Old Jan 10, 2003 | 03:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I heard excessive blow by from ring wear will do the same any ideas????????/
BTT
Old Jan 10, 2003 | 04:30 PM
ULTM8Z's Avatar
If you don't see blue smoke out the exhaust, you could likely rule out guide seals and rings. Also, leaking oil into the cylinders will foul the spark plugs really fast.
I'm assuming you've gone through all of the vacuum lines and checked the throttlebody/carburetor gasket? PCV valves? Charcoal cannister? Interior heater control vacuum lines?
Old Jan 10, 2003 | 10:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I'm comvinced its a blown guide. I told the guy he's either going to need the heads gone through completely and find out what damage running at 3K+ ilde has done to the bottem end or go with a good used engine (safe bet) either way the prices to fix this turd are near equal $25.00 more for the used engine. I'm glad I only drive GM's.
Old Jan 10, 2003 | 10:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea, all the vacuum lines were plugged and gaskets were all replaced.
Old Jan 12, 2003 | 05:42 PM
Vader's Avatar
Did you try the test with the PCVvalve capped/disconnected? The wrong valve (or a stuck one) could develop a lot of crankcase vacuum in a hurry.
Bubbajones_ya
Aug 28, 2015 02:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
