what CAUSES backfires?
Old Jan 11, 2003 | 01:22 AM
squirrelybird's Avatar
ok, i have been noticeing lately my car will backfire occasionally upon acceleration. happenned tonight, seemed like it backfired through the intake, not exhaust, immediately upon hard acceleration. only happens then. what does this mean? rich? lean? could this be due to ignition or timing problem??
Old Jan 11, 2003 | 02:24 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
My eng acted like that too. In my case the cam had worn out. The exhaust valves on a couple of cyls were just barely opening.
Might wanna remove the valve covers and start it up. See if the rockers are a rock'in.
A lean condition will cause a backfire thru the intake too.
Could be something as simple as a fuel filter starting to clog.
Old Jan 11, 2003 | 03:51 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I agree, usually a lean condition will cause it. If your fuel filter isn't plugged, the fuel pump may be bad.
Old Jan 11, 2003 | 04:42 AM
1a12's Avatar
very possible that your timing is not advancing right. Might want to check out your timing.
Old Jan 11, 2003 | 04:49 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
mine was doing that and it turned out some of the polly locks were loosening up(the noise diden't chang 'cause the variable duration lifter I use are alaways noisey)
Old Jan 11, 2003 | 05:50 AM
Andy Bush's Avatar
A worn distributer can do it. Easy to check, just use a timing light and see if the timing stays fairly constant at steady revs or if it wanders around indicating a loose shaft. You can't always feel the loose shaft.
Old Jan 11, 2003 | 08:42 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
My header bolts came loose, caused me to blow a header gasket. When the gasket blew, it caused my car to backfire.
Old Jan 11, 2003 | 12:38 PM
thanks guys, these all seem possible. i changed the fuel filter over xmas holidays. how bout a clogged up Cat converter...would that do it? also, i fear i may have timing issues...not much play in chain though (bout 4*), but timing may be off (no timing light, and never made it to mechanics over holidays). how do you check fuel pump?
thanks guys
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
