idle question
Old Jan 11, 2003 | 04:43 PM
mauibluebird's Avatar
idle question
Just bought an '89 Formula with 305tpi. When I come to a stoplight and stop the idle is at about 1k. After a few seconds it slowly starts dropping in increments until it reaches 600 where it should be. Is this normal? Could it be a problem with the IAC?
Old Jan 11, 2003 | 05:16 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Sounds like your throttle is sticking a little.
Old Jan 11, 2003 | 07:18 PM
Vader's Avatar
...or the IAC is gummed and sluggish. You might try cleaning the throttle body to solve both issues, then remove, clean,and lightly lube the IAC pintle rack gear. It only takes a very little contamination to "kill" the IAC operation:
You should also closely inspect the throttle cable for damage or fraying.
Old Jan 11, 2003 | 09:44 PM
Kiwi-85IROC's Avatar
Vader...Can the IAC be taken out and cleaned and then put straight back in without having to do all that tps reset etc etc which I know nothing about.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
