Mixing Synthetic oil ???
Old Jan 12, 2003 | 09:56 PM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
Where I live , I can get castrol full synthetic in a 5 quart jug thats $10.00 cheaper than the Mobil 1 . I use Mobile 1 now , but can I change to another brand of synthetic w/o hurting the motor ?? Anyone know??
Old Jan 12, 2003 | 10:35 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
I don't see it as being any problem. Syntec is probably every bit as good as the Mobil one. I personally don't use synthetics, but i'm not a one brand of oil kind of guy either. I switched between Pennzoil, Valvoline and Exxon Superflo and I don't notice any differences.
Check out my Survey post I put up, cast a vote, and see what a bunch of other third gen owners are using in their cars.
https://www.thirdgen.org/techbb2/sho...hreadid=152470
Old Jan 12, 2003 | 11:58 PM
Vader's Avatar
Brent,
That shouldn't be a problem, as long as you never mix two types of synthetic in the same change. The little that might be left from the previous oil change shouldn't cause any trouble, but mixing a polyalphaolefin based synthetic (PAO) with a polyol ester (POE) based synthetic or a dialkylated benzene based synthetic can have serious consequences. I'm not sure about Syntec, but Mobil 1 is a POE based lubricant. I believe that most synthetic engine lubricants are, but all three types can be used in crankcases, so beware.
Old Jan 13, 2003 | 05:42 AM
ede's Avatar
ede
from what i hear or read castrol synthetic isn't very good, but tat's your choice to make. i've mixed dino and synthetic ,differant makes and weights and never had a problem.
jrdturbo
Mar 31, 2016 02:58 PM
tyeo098
Nov 30, 2015 06:27 PM
skinny z
Oct 5, 2015 06:23 PM
TheExaminer
Sep 28, 2015 02:28 PM
CatmanFS
Sep 19, 2015 09:00 AM
