What preventative maint. should be done?
Old Jan 12, 2003 | 10:53 PM
84 Challenge's Avatar
Here's the deal! Have an 84 Iron Duke SC. Got her back in May last year. Changed the oil, air filter and belts the day I got her. She's sat from June till about now (fuel delivery problem). The car is in need of some serious maint. Here's what I'll do in the next few weeks: change oil/filter again, new plugs/wires, new dist. cap/rotor, change trans. fluid, change rearend fluid, radiator flush and change power steering fluid. Is there anything else you guys/gals would recommend in the maint. department? Just redone the brakes, so the brake fluid is brand new.
Thanks,
Brandon
Old Jan 13, 2003 | 09:27 AM
Vader's Avatar
84,
Along with the items you've already listed, I would add the following:
Vacuum hose inspection;
PCV valve cleaning/replacement;
EVAP canister filter replacement;
PCV breather filter replacement;
Wheel bearing repack (if not done with the brakes);
Fuel filter replacement;
Check steering/suspension/drive line rubber bushings and lube with silicone oil;
Inspect steering components and lube all fittings (synthetic grease, of course);
Clean all hinges and latches with spray cleaner and a towel, then lightly lube with 20W engine oil (no spray oils!). Don't forget the pivots for the hood and rear hatch struts;
Clean the radiator air side with a garden hose in the reverse direction through the radiator;
Inspect shocks and strut cartridges for leakage and bounce test;
Check/tighten panhard rod and brace mounting bolts;
Clean and lubricate all body rubber seals with silicone;
Test/replace the radiator cap;
Ditto the fuel filler cap;
Lubricate the wiper linkages with 20W;
Clean and lubricate the brake cables with white lithium grease (if not already done with the brake service;
When you flush the cooling system, replace the thermostat;
If you don't know when it was last done, replace the oxygen sensor;
Inspect the coolant port plugs on the underside of the intake manifold. For some reason, all three of mine leaked there, and I had to remove and reseal the plugs. Of course, all of them were installed bass-ackwards in my cars:
theshackle
Mar 5, 2017 06:37 PM
djmarch
May 8, 2016 11:32 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
BurlyChev
Aug 22, 2015 11:42 AM
theformula
Feb 25, 2001 05:34 PM
