Adjustable Master Cylinder
Old Jan 16, 2003 | 02:08 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
For a hydrolic clutch, what does this do? Can you modify the friction point for the clutch? (i.e. less pedal travel to engage the clutch?) or is it something completly different. Does it come w/ the slave cylinder also (usually?) Will it even work with the clutch type in a 93-97 t-56?
Old Jan 16, 2003 | 11:37 PM
Corry's Avatar
Car: 1987 Trans Am
Anyone at all? If that isn't adjustable the way I described, is there any kind if modification like that available?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
masonta
Sep 1, 2015 06:40 PM
