Cowel/Scoop options
Old Jan 17, 2003 | 02:51 PM
HamsterOnaMission's Avatar
Cowel/Scoop options
Which option would be most effective on my hood?
Cowl Induction?
Functional crossfire style scoops?
Both?
The hood i'm making is kind of like a higher daytona hood streched to meet the body lines on the stock hood
Anyways, it has a cowl shape and will go back close to the windshield, and would be able to make use of the high pressure area there, also, it has the stock scoops/dummy vents which could be made operational.
When sealed up to the carb or throttle body, would the crossfire style vents prduce a 'boost' effect at higher speeds if the hood was sealed off? or would it merely function as a glorified cold air intake?
If it is merely a glorified cold air intake, would it add or subtract from the functionality of a cowl hood?
I will most likely be running a stealth ram set up, or alterntively, an edelbruck efi set up when all is said and done
Old Jan 17, 2003 | 09:25 PM
Damon's Avatar
The Cowl hood IS ram air, believe it or not. The base of the windshield is a high pressure area. And it's basically non-turbulent air.
Neat way to hook it up if you're using a carburetor setup is to buy a cold air inducion system designed for a cowl induction hood from these guys:
ramairbox.com
Cost is pretty reasonable but you'll have to tweak it to make it fit your car exactly- easy to do since it's just fiberglass and some tubing.
Old Jan 18, 2003 | 12:17 AM
cool thanks
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
