after market ignition
Old Jan 17, 2003 | 08:43 PM
pskel350's Avatar
what is a good rule of thumb as when you should upgrade to an aftermarket ignition? I have a non cc HEI distributer now, at what point in my mods should that be upgraded and how?
Old Jan 17, 2003 | 09:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It may just be my opinion, but unless you you burn a lotget to the point where of fuel and run at high RPM's, there's probably not much value in spending money on a new ignition system.
I'd be willing to bet someones else's paycheck that the majority of those who:
idle better
run better
increased fuel milage
etc...
Needed a good tuneup anyways.
Old Jan 18, 2003 | 12:17 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The factory pices are pretty good, actually. But when you decide to spend a couple hundred dollars, get a good cap with brass terminals (factory are aluminum). A higher voltage coil, Proform makes a nice inexpensive 50000 volt unit for $40 or so. And a high performance module so you are getting good spark at 5-6000 rpms. Again, Proform makes a nice inexpensive one.
Wires are iffy, performance wise. But spiral wound wires are the way to go for low resistance.
Forget about those digital boxes unless you are using nitrous or a blower. They are overkill.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
RedLeader289
Sep 23, 2015 06:50 AM
