HEADS: I have the cast numbers, what are they?
Old Jan 18, 2003 | 02:31 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I just adjusted my valves today. (I enjoy being able to step on it with out hearing the clatter now.) Anyway, I wrote the cast numbers down from my heads.
Can someone run the numbers and tell me what kind of heads I have?
The passenger's side reads :
3927188
E2201 GM 53
The driver's side reads:
3947041
ka s GM 8
Oh yeah, when I was doing the valves, why doesn't oil spit out at me? It only seemed to spit at different tightnesses of the rockers. If I loosened it, oil would spit. If I tightened it, the oil would seep. Should I change my oil a few times to clean out the engine?
Old Jan 18, 2003 | 03:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You have one 327 2-barrel 74cc head (188) and one double-hump 64cc hot-rod head (041) from a 302 or LT-1 type of motor. So half your cyls are at one CR with great flow, and the other half at a much lower CR with much poorer flow.
Yuck.
Old Jan 18, 2003 | 03:17 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Well if infact these are the casting numbers on your heads.
One side is a 69/70 307/327 low perf 74cc head
while the other side has a (041) 69/70 302/350 hi perf head
64cc
Must run real good. Best look into that one.
www.mortec.com
Old Jan 18, 2003 | 05:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
lol... like trying to run a marathon with a work boot on one foot, and a nike running shoe on the other.
Old Jan 18, 2003 | 05:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Nice analogy!!!
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Who in the world built your engine?
Old Jan 19, 2003 | 05:01 PM
I am not mistaken. I just looked again. It seems to run fine acctually. what should I do??? Also, since I am going to have to look into some other heads, how do I tell what are the hi-po heads and which are the crap heads?
Old Jan 19, 2003 | 05:03 PM
also, would this cause any damage?
yeah, they look exactly the same too...
Old Jan 20, 2003 | 12:26 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Go to www.mortec.com and print out the sbc heads list, then when you look at heads to the numbers up on the sheet and find out what they are!!
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
