smog equipment removal
Old Jan 20, 2003 | 01:39 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I'm registering my car where there is no emmisions and want to remove all the smog junk. What kind of problems will I encounter if I strip everything out? I would assume that trouble codes will be popping up at the least. Anyone done this? By the way the car is a 90' RS.
Old Jan 20, 2003 | 01:59 AM
MdFormula350's Avatar
welcome to the boards!
i ran a search on found this thread, it might help you out
https://www.thirdgen.org/techbb2/sho...hlight=smog+rs
good luck.
Old Jan 20, 2003 | 02:04 AM
llvll4l2c91350's Avatar
I just did mine. Removed the pump, diverter valves, rubber hoses and replaced the check valves with caps. There is no code for the AIR system so I'm not worrying about a check engine light going off. Only problem you may end up having is a prematurely clogged CAT, but since there's no emissions, might as well remove that too. Good mod to do to get rid of some weight and free up space under the hood.
Old Jan 20, 2003 | 02:08 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Hell yeah, thanks for the help. Those hoses and crap really got it the way when I installed my headers. Unfortunetly I bought the headers with AIR fittings. Guess I'll just weld those closed.
Old Jan 20, 2003 | 02:33 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i consider the computer controlled carb and distributor emmissions ****...**** it all, build that bitch up
Old Jan 20, 2003 | 02:42 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Now thats what I'm talking about right there. Rip all the crap out, computer, electrical, smog. Nothing but air,spark, and fuel. My dream........ holley dominated ZL1 built to the hilt.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
