Checked ignition system, now backfires!
Old Jan 19, 2003 | 08:09 PM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
I went through the ignition system checking out every part (because i was experiencing a power loss)
anyway, it turned out to be a couple burned wires, so i replaced them, and now the car backfires
the car is getting spark at teh coil, and i tested it at the plug (jsut tried number 2) : my guess is taht the timing is off, because i turned the crank by hand (well, with a ratchet). i cant see why that would cause the timing to be off, but im just shooting in the dark now, and i'm about the take a 20 lb sledgehammer to this damn car
anyway, any suggestions would be greatly appreciated
thanks!
Old Jan 19, 2003 | 11:43 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Are you sure you got the wire connected to the correct plugs? Mine did the same thing when I plugged them up wrong.
Old Jan 20, 2003 | 12:21 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You crossed a couple spark plug wires. Look them over and make sure the firing order is correct when you put them back on.
Old Jan 20, 2003 | 12:24 AM
Raiden's Avatar
I hate ignition woes!
Old Jan 20, 2003 | 02:28 PM
DuffMan's Avatar
Car: '99 Cobra
Transmission: T-45
Axle/Gears: 4.10
i have completely rewired the spark wires probably 5 times now, and my dad has checked it everytime, and its the same
i read another post about how the distributor can get become 180 of the rest of hte engine, so you have to move the wires 4 spots ahead - i tried this with the same result as if i tried to start the car with the coil disconnected - just cranks, but at least it doesnt backfire
i have absoultely NO idea what it could be right now, and i hate to have to call my mechanic to come out and repair it
Old Jan 21, 2003 | 08:25 AM
Vader's Avatar
Duff,
Turning the engine won't change the timing. Only loosening and turning the distributor will do that, unless the timing chain has slipped. Also, there is no way to get the distributor position 180° out of phase unless the distributor was removed.
Recheck the wires for #5 and #7. Those two are very easy to get mixed up.
Old Jan 21, 2003 | 11:57 AM
DuffMan's Avatar
Car: '99 Cobra
Transmission: T-45
Axle/Gears: 4.10
well, than i guess the timing chain is not busted, becuase when i turned the crank, the distributor moved also
therefore i must have wired the car wrong?
thanks a lot for the response vader!
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
