ram air/ cold air induction
Old Jan 20, 2003 | 07:59 PM
87camaro kid's Avatar
Car: 1987 Z28
i hope this isnt a stupid qustion but is there a diffrence between ram air or cold air induction? i have an 87 z28 that i put ram air on would it be any diffrence to make it cold air induction if there is even a diffrence?
Old Jan 20, 2003 | 08:20 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I believe cold air would just refer to something other than hot engine compartment air. In a cold air set up the intake is routed out of the engine compartment. Example would be a L69 dual snorkel setup.
Ram air would mean the air is forced into the intake. An example of this would be an ss hood set up with a functional scoop.
Old Jan 20, 2003 | 08:21 PM
patrickm00's Avatar
some people tend to use them interchangeably, but i guess the technical difference is whether the system is designed to pull in air from outside the engine bay (cold air induction) vs. using the airflow against/over the car (which is speed dependent) to force additional air through the intake at pressures greater than the (ostensibly 1atm) ambient pressure.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
jimmy harris
Aug 31, 2015 03:09 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
