what rpm to set timing at?
Old Jan 21, 2003 | 04:25 PM
holmes677's Avatar
What RPM are you supposed to set the timing at? Ive heard at warm idle, but my idle ranges from 700-1200 when warm so a specific number would be helpful. Also what do you TPI guys out there have yours set at?
Old Jan 21, 2003 | 04:29 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
soposted to be idle, and your car should idle at around 700rpm, but thats for carb, tpi might be a little different then carb on this though.
Old Jan 21, 2003 | 07:43 PM
llvll4l2c91350's Avatar
Sounds like you have a bad idle problem that should be taken care of first. When warm the car should stay around 600 or 700 RPM. At least mine does, and it's a TPI. I set mine at factory specs which I believe is 6* BTDC.
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
perZ
Aug 15, 2015 01:17 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
