Oil pressure gage fluctuation
Old Jan 22, 2003 | 01:44 PM
mike48's Avatar
Car: 89 RS (original V6 car)
Engine: 355 TPI
Have any of you had trouble with your stock electric oil pressure gage doing strange fluctuations? Mine seems to stick either high or low. Once I saw it jump from 30 psi to 60 psi, when I was cruising at 70 mph. I think the pressure sensor may be sticking. I just don't want to change it if it could be something else. By the way, I just put in a new engine (except the oil pressure sender!); it acted the same way with the old engine that had 140,000 miles. I wish I would have put a new one in. Thanks for the opinions!
Old Jan 22, 2003 | 02:57 PM
Morley's Avatar
Sounds like the diaphram in the sender is on its way out. If you do replace it, go with an AC Delco and save yourself some headaches. I tried 3 different aftermarket ones and none lasted more than a year. The Delco one is on year 7 and doing fine.
Old Jan 22, 2003 | 04:13 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
morley, what place did you get your ACDelco from? The Autozone by me only had some generic, and the threads were different, i couldnt even screw it in!
my needle bounces around, only a few psi, but it always annoys me.
Old Jan 22, 2003 | 04:25 PM
Morley's Avatar
Chevy dealer, about $30 at the time.
Old Jan 22, 2003 | 07:07 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
i have a problem but it moves around depending on how much throttle i have, at idle its just about 60 or a little under, when im accelerating it moves to over 60 and stays. is this normal, mind you i have a new engine with just over 1k on it. no oil problems but a leak.
Old Jan 22, 2003 | 07:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just change the sending unit. They go bad all the time. Especially those fine quality OEM AC Delco ones...... I'm sure that all these broken ones you see people talking about were working just fine, until somebody put something else in.
My AC Delco one died in about 88 or so, I put in some kind of cheap aftermarket s****, still seems to work fine. Only has about 200,000 miles on it in the 13 or 14 years since then though (twice the lifetime of the high-quality original one) so it might not be all the way broken in yet though.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
