Car won't start, after being turned off
Old Jan 22, 2003 | 01:51 PM
jaysonds's Avatar
Hi all! I have an '88 305 TBI Camaro. The other day, I was driving to work, and had to stop for gas. When I got back in the car, it would not start, and the check engine light would not come on. I had to leave the car there.
When I went later that night, with the tow truck driver, it started right up.
I warmed it up the next morning, and turned it off to test it, it would not restart. And, again no check engine light-all the other lights work and the radio...etc.
Here are a few things that I noticed:
It tries to turn over.
It drives perfect when running.
Check engine light-not on after trying to restart.
I changed the ECM fuse-I always carry a spare.
I will have to check to see if I can hear the fuel pump when I get home(I am at work).
Does anyone have any ideas what the problem could be? Anything I should check? I am stumped. I would rather have some direction to start. Unlike last time, when I took my gas tank apart to get to my fuel pump-when it was a ECM fuse.
Thanks,
Jayson
Old Jan 22, 2003 | 02:01 PM
fanman's Avatar
Sounds like the starter solenoid is soaking up too much heat. You could try putting a heat shield around the solenoid. Or you could install a remote one.
https://www.thirdgen.org/newdesign/tech/solenoid.shtml
Old Jan 22, 2003 | 02:52 PM
Morley's Avatar
If the check eng light will not come on with the key on when it isn't starting then I'd suggest replacing the fuseable links down by the starter. They (one or both) are most likely breaking down and the heat from the engine running is making them flake out.
Old Jan 23, 2003 | 04:56 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I had a very similar problem.
It turned out the rubber pick up hose connected to my fuel pump had become torn.
During cold starts, the tear was small enough so that fuel was still able to reach the engine. The car started up and ran fine.
During hot starts or after shutting the engine off, the tear expanded due to fuel pressure and friction so that fuel never got out of the gas tank. The end result was that the car would not start until the tear contracted through cooling (done be letting the car sit for a few hours)
If you haven't checked your fuel pressure or replaced your fuel pump lately, I bet this is your problem.
Old Jan 23, 2003 | 09:27 AM
TBurke's Avatar
Check and see if there is a fuse on the passenger side fender. If so check the link from the battery to the fuse. It may be loose. I had this happen. Car cranked but no fuel or computer(engine light). If you have changed the battery cable in the past this is very likely. Let us know. I doubt it is a starter problem but you never know.
Old Jan 26, 2003 | 12:39 PM
jaysonds's Avatar
Fix but not sure really why?
Ok,
First off, I changed the battery since it was pretty old. Simply changing the battier fixed my issue.
Don't ask my why the cars ignition light would not come on after it warmed up; when every other electrical component worked without a problem.
Must have been, as what someone posted, the batteries cell failing out and creating a negative impulse with flux compositor which unlocked the muffler bearings causing the car to quabobulate on the slagin cam.
However, I learned something new with each and every post.
THANKS for assisting.
Jayson
88 Convert
Old Jan 26, 2003 | 03:01 PM
singleslammer's Avatar
flux campacitor, muffler bearings....lol:sillylol: you can go to warp 7 now!
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
killer777
Aug 8, 2015 02:47 PM
