Problem with T56 AND HOOKRE LT headers, Please help ASAP
Old Jan 22, 2003 | 05:28 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
I'm trying to get some second opionions on what to do about this problem. Here are some photos that explain it. The collector is touching the bell housing which will not allow installation of the headers on to the head. What do you guys think? Roy at thirdgenresource said the only way is to either replace with shorty's or grind away. I thought the sme way about grinding but is it safe to grind on the collector or bellhousing?
https://www.thirdgen.org/techbb2/sho...hreadid=156541
please click there to see some pictures he took , it is posted in the exhaust section as well
Old Jan 23, 2003 | 12:19 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
ttt
Old Jan 23, 2003 | 12:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
start grinding the bellhousing and a little off the header flange and see where that gets you. Dont enlarge the holes for the head bolts
Old Jan 23, 2003 | 03:01 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I remember reading somewhere that minor grinding is required on the bellhousing with the LTs....I would think this would be the best and easiest solution.
Old Jan 23, 2003 | 03:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
this post may help.https://www.thirdgen.org/techbb2/sho...hlight=traxion
Old Jan 24, 2003 | 01:26 AM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
ttt
tricky1
Aug 23, 2015 01:17 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
