car will not start
Old Jan 24, 2003 | 05:24 PM
dano69's Avatar
car will not start
I own a 92 Firebird with a v6 (3.1). Last week the car would not start (engine cranked but wouldn't turn over). I check the distributor cap (I had problems with this last year) and the contact were pitted. After I replace the cap, rotor and spark plugs (they were fouled) the car started immediately. The car was driven a couple of times, then on thursday the car would not start again, same problem, cranks but will not start. I tried starting fluid to see if it was gas related and no luck. I also pulled a spark plug wire and checked for spark. The spark was orange colored, I am thinking i have a weak spark. I am leaning towards either the pick-up coil or the coil. Any thoughts? Also, the car started to give an erratic idle when you go to stop. I jumped the computer and got codes 34 & 45. I know the 45 is the O2 sensor.
Old Jan 24, 2003 | 05:39 PM
89rocs's Avatar
Car: '89 IROC
Engine: 5.7lt 350 TPI
Transmission: Original :(
43: TPS (Throttle position sensor) out of adjustment OR knock sensor signal error OR low voltage at electronic spark timing control.
44: Oxygen sensor lean error.
You were right on the noise about the low power/spark it seems.
I hope # 43 helps you figure what the problem is bud.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
