Gas In Oil???
Old Jan 25, 2003 | 10:20 PM
red_82_z28's Avatar
Car: 1982 Z28
Transmission: 5-speed
Gas In Oil???
I just bought a parts Camaro for $250 dollars. everything is there. THe engine was taken out of the car. and the man I bought it from said when he drained the oil pan there was gasoline in the oil. what could cause this. or could he be talking water???
Thanks William
Old Jan 25, 2003 | 10:56 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
if it has a mechanical fuel pump, it is probably a bad fuel pump(leaking fuel into crankcase), if electric pump, it probably flooded/leaking injectors/ect.
Old Jan 25, 2003 | 11:06 PM
red_82_z28's Avatar
Car: 1982 Z28
It had a mechanical fuel pump.
William
Old Jan 26, 2003 | 08:14 AM
Dave Y's Avatar
Engine: 4.3L V6
the odds are it has a bad pump(the rubber diaphram inside is leaking)
Old Jan 26, 2003 | 08:55 AM
red_82_z28's Avatar
Car: 1982 Z28
Thanks dave youve took a big chunk of worry off my shoulder.
Thnks William
Old Jan 27, 2003 | 01:15 AM
Redline's Avatar
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
but what if it was electric
what could it be then
Old Jan 27, 2003 | 01:34 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could also be very, very worn out cylinder walls/rings... this happened on my old 305, it was basically shot when i got the car and ran on more oil than gas, but had a good fuel pump. I'm not 100% on this, but since the cylinder with the highest compression was only 60psi, i'm pretty sure this was it.
Old Jan 27, 2003 | 02:44 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
with my blower it would blow-by fuel into the cylinder under boost. i fixed it by installing a crank-case evacuation kit.
thats probably not your problem, but it can occur from blow-by (bad rings / warped cylinder walls)
now if theres a TON of fuel (mine was just a faint fuel smell in the oil. you couldnt see it.) in the oil then its prolly that stupid fuel pump.
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
