Hard starting when warm
Old Jan 26, 2003 | 08:52 PM
Nokternal7's Avatar
Hi,
I have an 83 trans am with a 4bbl carb. After I've driven it for a while and then turn it off for about 10 minutes, the car won't start. The thing will keep on cranking but won't start. One time I thought I was going to drain the battery from trying to start it. The only way to get it to start is to put the pedal ALL the way down while its trying to start.
Any ideas?
Old Jan 26, 2003 | 10:08 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
Have you checked the spark when it wont start? Sometimes when ignition module is going bad there is no problem when its cold. But after its hot you can lose spark all together or it is just too weak.
Old Jan 27, 2003 | 04:03 PM
86IROC350NY's Avatar
my problemq
Check to see if the ground from the engine to the frame rail is good...or even existent. i had the same problem a couple days ago.
--Dan
Old Jan 27, 2003 | 04:12 PM
Jza's Avatar
Jza
Check the coil, too. Those can get prone to heat-related problems.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
mustangman65_79
Aug 8, 2015 12:07 PM
