Fuel supply?
Old Feb 1, 2003 | 05:52 PM
Raiden's Avatar
Fuel supply?
I put my hand on the fuel supply line from the tank and noticed that is was pulsating. Is this normal or is my fuel pump on it's way out?
Old Feb 1, 2003 | 06:45 PM
T3am Z28's Avatar
I believe it's normal..
As long as the car is on, fuel is moving through the supply line.. hence the pulsating.. might wanna confirm this tho..
-LJ
Old Feb 1, 2003 | 07:00 PM
Raiden's Avatar
my fuel psi seems to be ok, but i'm having lack of HP issues and trying to rule things out. So far everything checks out? Spark, fuel, air....... I never thought the pump would pulsate?
Old Feb 1, 2003 | 09:28 PM
Vader's Avatar
Attach a gauge. If the pulsations are more than 2 PSIG, you may have a problem.
Some pulsation is normal. The factory installed a pulsation damper on many EFI cars, but they tend to fail, so many cars and a lot of replacement pumps never got the dampers. It doesn't seem to cause any system problems.
89fast5oh
Sep 27, 2015 09:04 PM
L98GTA87
Aug 25, 2015 02:23 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
PestilenceIV
Aug 20, 2015 03:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
