Engine Identification
Old Feb 1, 2003 | 08:14 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
My brother has an engine sitting outside his work, the heads are a 418 casting, couldn't find any info on mortec.com about them, the block itself has no number, but says GM Canada and 5.0 L on it. I guess it's a 305, but other than that I have no clue.
Old Feb 1, 2003 | 08:55 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
should have a casting number...it can be on either the right or left hand side of back of the block...usually if it has 5.0L or 5.7L on the left the casting number is on the right....
as for the heads, i think you probally misread the casting number, 6's and 8's look pretty similar, i think you have 416 heads which are 80-86 305 heads with 1.84"/1.5" valves & 58cc chambers...
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
