is there any difference between the 2 heads?
Old Feb 2, 2003 | 10:18 AM
rockfourone's Avatar
is there any difference between the 2 heads? i think i swapped mine around when i put them on. everything lines up and bolts up just fine though. is this a problem? also i noticed that the little brass ****/bolt/sensor/whatever that should be right between the spark plugs for #1 and #3 is now back by #6 and #8. what is that thing anyway? will this be a problem?
Old Feb 2, 2003 | 10:26 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
heads are interchangable from side to side. the little brass thingy is a temp sensor. you can leave it there and run the wire to it. or switch it to the other head.
Old Feb 2, 2003 | 01:33 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The only difference is the accessory holes. If you put them on the opposite, you wont be able to mount your accessories.
Old Feb 2, 2003 | 01:54 PM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Depending on what your running, the cooling fan sensor runs out of the coolant hole between 6 and 8 and the temp sensor for the gauge between 1 and 3. Sounds like you have a belt driven fan. There should be a pipe plug in the hole between 1 and 3 remove it and remove the brass sensor and swap them. everything else should be ok.
Old Feb 2, 2003 | 04:07 PM
mrr23's Avatar
Engine: 360 HSR
the bolt holes are the same when you switch the heads. the heads are the same no matter which way you turn them.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
