An intriging Problem
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Hey folks, here's a good one for ya.
The Vehicle: 1988 Chevy Blazer (sorry, not F-body......)
350 TBI
Automagic Tranny
The engine has 2400 miles on it, but has been in the truck for about a year. (assorted transmission problems....) Just long enough for the warranty to run out. I have checked the ignition system, get a nice fat blue spark from the tester, I have changed the spark plug from a known good cylinder. Leakdown is less than 10%, and the cylinder builds about 125 lbs. on a compression test. I have verified that there are no vacuum leaks, fuel pressure is good. The problem is that the number 7 cylinder is dead. The spark plug from this cylinder was kinda black, other plugs were a nice shade of tan.
Now I seem to remember something about GM having a problem with the back cylinders running lean on some of the TBI motors. However, I don't want the customer to spend a couple hundred dollars on a new manifold, and not solve the problem.
I am open to any and all suggestions, I know you folks out there are pretty smart, I have already received a great deal of help from you on my Firebird. (which is currently down for the count, that &%#$$ borg warner rear end went out......)
Thanks Folks.
350 TBI
Automagic Tranny
Thanks Folks.
Ploegi,
As I'm sure you're aware, lean isn't black. Is the owner one of those notorious "non-warmup" hard drivers? You may have oil problems in that cylinder making the carbon, not fuel. It sounds unlikely at only 2,400 miles, but there may be seal/ring/gasket damage allowing some oil into that chamber or intake runner.
