Transmission Problems
Old Feb 6, 2003 | 10:02 PM
Joeboy's Avatar
Ok I have a 82 firebird with a 305 and a TH350 trans. Its been running like crap for the past couple days. I accidently put in some type F fluid. (I didnt know there was a difference) so I changed the filter and fluid today and used Dexron 3. But its still not better.
Symptoms: Drive niceand slow and it shifts fine and hits third gear at like 25 MPH. Try and give it a little gas and the problem comes in. Its not slipping but its like its not completley hooking up. I cant get all the power I used to be able to get. It wont shift unless you let off the gas. It will just stay revved to a certain RPM.Like its about to shift. Same thing with 2nd-3rd gears.Once your cruising in third you floor it and it immediatly revs way up but you really go nowhere.
Now if you really floor it of the line, it just revs high and gets no power and you cant peel out or anything (It used to just slam the tourqe to the pavement)But when you hit the 2nd-3rd shift Theres a bad clunking and shaking for about 4 seconds. Sounds Real Awful. And after you get that reaction,If you go to park it the shift linkage will act up. Every gear but Park is Drive. Turn off the engine and shift through, and every gear is nuetral.
I dont know much about trannys so I dont know whats the matter or what to do. Any help would be apprectiated Im watching hondas take off while Im practically stuck in the mud. This sucks
Old Feb 7, 2003 | 12:27 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
does your shifter feel more loose than normal? If so, your linkage could be loose. It could also be your TV cable needing adjustment. If neither of those is the problem, I really don't know what to tell you... hope this helps some.
Old Feb 7, 2003 | 10:16 PM
Joeboy's Avatar
The Shifter feels fine.
If I try to power brake nothing happens. The tourqe converter jsut spins. I think it might be all gummed up from the type F fluid if thats possible. How would I go about draining all of the tranny fluid. Including whats in the converter. And flushing the rest out.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
