I got 4 codes - bad ecu, or what?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Code 33, 34, 42, and 43. Replaced the map with a known good one, no difference. If I crank the car, and shut it right back off, it sets code 33, 42 - if it runs for about 15 seconds or so (maybe 10) it sets 34 and 43. The knock sensor was disconnected, but I hooked it back up. Timing set to 10º BTDC.
I can get a ecm from the junkyard for $20, no return. How on earth can one test the ECU to see if it is bad?
Yep... I always clear all codes, then try again to see what comes up.
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Have you tried TPS voltage yet?? thats part of code 43. Sounds like you've already tried the knock sensor. What about the ESC (electronic spark control).
I'll check the tps voltage... hey, is there a ESC module or something I can check? Where at?
Yes, the ESC is located behind the mastercylinder on the firewall. I don't have a pic but I'll get one later for you. Remember the TPS voltage has to be below 1.0 vdc when in the throttle is closed.
