What would cause a decrease in idle rpms?
Old Feb 7, 2003 | 01:32 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
From when I got the car, whether it be a 85 degree day, or 10 degree winter day, on the first start of the day, it would idle at 1000, then when it warmed up it would idle at 750. Its stored now and I start it once a month. And when Ive been starting it this winter, I got the usual 1000 cold, 750 warm.
Now these past 2 months, I started it two times, both being 20-30 degree days, and it idles at 750 ice cold (First start), and 750 warmed up to operating temp. No SES light, and it idles just as good as it always did, just not as high when cold.
Anyone know whats up? Im positive its not my tac being inaccurate.
Old Feb 7, 2003 | 06:26 PM
Car: 1988 IROC-Z
Engine: 427 SBC
No one has a clue?
Old Feb 7, 2003 | 06:58 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Sounds like a sensor or something to that effect. Perhaps its getting innacurate water temp readings or something. This is mostly educated guessing, but I figured I'd toss something out to think about. But if you get no codes, and she runs fine, probably not a big problem... at least IMO.
Old Feb 7, 2003 | 08:12 PM
Vader's Avatar
As usual, the first advice I would offer is to clean up the TB and IAC air passages, then make sure the IAC is working, and minimum air and TPS are set corectly.
Old Feb 7, 2003 | 08:29 PM
Car: 1988 IROC-Z
Engine: 427 SBC
All that is good accept the TPS, never tested it.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
masonta
Sep 1, 2015 06:40 PM
