intake gaskets
Old Feb 8, 2003 | 01:28 AM
2birds40's Avatar
intake gaskets
allright guys i am in the process of changing my intake gaskets don't need any help with that but what do you guys recammend for removing the old gaskets from the heads also i broke some of those stupid plastic vacume lines what do i do about those thanks for your help
Old Feb 8, 2003 | 02:23 AM
2birds40's Avatar
come on guys i want ot get my car back togher by morning help please
Old Feb 8, 2003 | 02:33 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Uh you use a gasket scrapper! Or you can use a razor-blade. Go to the autoparts store and get a scrapper and some vacuum lines.
Old Feb 8, 2003 | 02:35 AM
radiateu2's Avatar
on cast iron head use a paint scrapper and then a scotch pad you know the green ones your mom uses for her pans lol. on the aluminum in take I use a plastic scraper and a scratch pad and some Simple Green or Tide laundry detergent on that too brake cleaner works ok as long as it is non clorinated. The clorinated type leaves a residue and corrodes aluminum. For the vacuum lines just take the pieces that broke to the parts store and replace them. Just make sure you mark the vacuum lines so you know where they go. Actually I just threw those plastic hoses away and replaced them with new rubber vacuum hoses.
Old Feb 8, 2003 | 02:43 AM
2birds40's Avatar
thanks guys i know about the scapers i just wasn't sure about using them on this stuff didn't want to mess anything up as far as the vacum lines i have no idea where they run to could i just clamp some rubber ones on where i broke them
Old Feb 8, 2003 | 02:49 AM
radiateu2's Avatar
from one end to the other find out where each one goes to then just leave enough to slide the vacuum lines over the old plastic tubing try a single edge razor blade to cut them.
Old Feb 8, 2003 | 02:53 AM
2birds40's Avatar
thats what i wanted to hear thanks
Old Feb 8, 2003 | 06:04 AM
2birds40's Avatar
okay guys i have been out in the garage for hours i haven't even got one head clean is there something different
Old Feb 8, 2003 | 06:27 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if you have air tools a wizzer wheel should have em nice n clean in a matter of a minute or so.. thats how i do it..if not i guess use scrapers like everyone else is sayin? good luck
Old Feb 8, 2003 | 10:30 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Permatex gasket remover in the aerosol can. Nasty **** though, will remove paint (actually it does this really, really well). It doesn't really <i>remove</i> the gaskets, but softens them up enough to easily scrape them off.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
