What is this?
Old Feb 8, 2003 | 07:40 AM
vwdave's Avatar
What is this?
There is a canistor under the duct work for the air cleaner on my car. Is this a vacumn canistor? Can anyone tell me more about it?
Old Feb 8, 2003 | 10:12 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
ithink you arefeering to the charcoal cannister. if thats it, its used to absorb gas fumes. i may be wrong as that stuff is gone from my car.
Old Feb 8, 2003 | 10:15 AM
vwdave's Avatar
Ahh ok. What benefits are there to removing that? How do I do it?
Old Feb 8, 2003 | 10:21 AM
craig's Avatar
Car: 86 camaro
all it does is keep fumes from exiting the car, just plug the hoses . no benefits , just looks. verify with someone that knows that lives by you to be sure we're talking about the right part, don't want to mess up your ride.
Old Feb 8, 2003 | 10:23 AM
vwdave's Avatar
I'll take a pic of it monday and post it.
Old Feb 8, 2003 | 06:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If indeed it is the charcoal canister, it also provides the vent to the fuel tank. Just plugging the lines will produce a vacuum in the tank as fuel is pumped out. End result - no fuel flow.
Old Feb 8, 2003 | 07:55 PM
craig's Avatar
Car: 86 camaro
my fuel tank has its own vent , back by the rear seat. sometimes its hard to give advice half a continent away
Old Feb 8, 2003 | 08:10 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
It's part of the EVAP system. You wight as well just keep it. Back before EVAP systems, fuel tanks just vented a ton of HC's into the atmosphere. Now the systems are sealed and the vapor that normally was vented is instead purged into the motor to be burned.
