can i adjust my idle?
Old Feb 8, 2003 | 12:21 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i want to know if i can adjust my idle somehow? and will it affect my computer if i turn it up?
Old Feb 8, 2003 | 12:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
you can fiddle witht eh min. air adj. screw but id leave it stock if you cant burn a prom with a new min. idle speed. If there isnt a good reason to do it, id leave the idle where it is.
Old Feb 8, 2003 | 01:00 PM
1987gt's Avatar
Car: 1989 GTA
well their is kinda a good reason i have under drive pulleys and my amp meter goes down because it idles kinda low @ like 650-700 in drive and like 800 in park i get dimed lights at night so i would like to go about a 100rpm more i did with my foot and it seems to make a big difference in the meter.
Old Feb 8, 2003 | 01:28 PM
Car: 88 Camaro SC
Engine: SFI'd 350
hmmm... what size pulley is on the alternator now? I suppose you could find a smaller dia. pulley for the alternator, that would help. Kind of self defeating gettign a smaller pulley with a u-drive system but the alternator is one accessory that works better at high speeds.
Old Feb 8, 2003 | 01:34 PM
Vader's Avatar
Here we go again...
More underdrive sheave problems. I wish the "Search" feature was working. I could probably find a hundred posts like this. People that sell these systems conveniently forget to mention the negative effects. And also conveniently forget to tell you that the electrical load is a constant, so you'd actually be better off only buying underdrive sheaves for the steering pump and water pump only.
No, you cannot change the target idle speed without reprogramming the ECM. Adding throttle angle will briefly "fool" the ECM, but you'l have other problems, like low IAC counts, MAF errors, etc.
Old Feb 8, 2003 | 06:42 PM
1987gt's Avatar
Car: 1989 GTA
yeah i know all kinds of people have had problems with the under drive pulleys what can i say im another fool trying to get power at any cost lol. i guess when i order a chip i can have them bump up the idle a bit right? would that be the answer? i need a chip anyways. cant i just get a higher amp altenator?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
