Question about Blown Head Gasket? Please Help!!
Old Feb 8, 2003 | 02:35 PM
92camaro's Avatar
I took my car out last night for alittle while. Everytime I would get on the car it would puff out white smoke and it would smell like burning antifreeze. I took the car home. The car runs fine, does not run hot and the oil looks fine and there are not bubbles in the raditor after it's ran. It is a carbed 350. I look around the intake and the gasket looks wet looking. Do you think my entire problem is a leaking intake gasket. Could it leak antifreeze/water into the intake port of the head and then burn off and produce the white smoke. I am just wanting to rule out the blown head gasket. Thanks
Old Feb 8, 2003 | 02:40 PM
Morley's Avatar
Could very well be an intake gasket. Pull the spark plug at the corner where the gasket is wet and have a look at it. You could also do a compression check to rule out a head gasket.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
