Will the 90-92 dash work with a carburetor??
Old Feb 9, 2003 | 01:53 PM
CamaroX84's Avatar
I currently have an 84 Camaro that I converted to TPI, and I have the original dash in it with the cable-driven speedometer. I am ditching my TPI and going back to carb, so I will be ditching the 730 ECM. I have a dash from a 92 Camaro (electronic speedometer) that I want to put in my car. My question is, will I be able to use this dash without the 730 ECM. I have a speed sensor on the car, it's just not wired up. Also, should I use my old LG4 harness/computer when I switch it back to carb? Any help would be greatly appreciated. Thanks in advance.
Old Feb 9, 2003 | 02:41 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i don't know the answer sorry. But why you getting rid of the TPI?
Old Feb 9, 2003 | 03:17 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
I agree you shoul keep the TPI. Especially on a 305 but as for your dash working check with JET trans they could probably help with your problem
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
beachrodder
Aug 25, 2015 08:05 AM
beachrodder
Aug 7, 2015 04:27 PM
