Block stamp decode
Old Feb 11, 2003 | 11:11 PM
SgtSkip's Avatar
Block stamp decode
Is there a chart around to decode a block code stamp? Here's the numbers off of this 350...
13Z433980 (these are small numbers)
U01I60KK (these are large numbers after the small numbers)
the 1I is debateable. It was a bit hard to make out.
Any input would be greatly appreciated!
Old Feb 11, 2003 | 11:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The small numbers are the last part of the original vehicle's serial number (numbers matching etc)
U01I60KK
V, not U is Flint engine plant
0116 is January 16
OKK is probably CKK
CKK can be a 1972 350. Originally had a manual trans. It was classified as an L48. 175hp, 4 barrel. Found in A F X body cars.
CKK can also be a 1973 350. TH transmission. Classified as an L65. 2 barrel. Found in B A X body cars.
Old Feb 11, 2003 | 11:28 PM
SgtSkip's Avatar
Way cool! Thanks for the info. I just found a sight with the codes as well. I was pulling my hair out trying to figure out the OKK! I should have remembered about the VIN code too.
Semper Fi
92projectcamaro
Dec 8, 2015 12:25 AM
thunder57
Nov 7, 2015 02:28 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Sep 29, 2015 10:18 PM
92projectcamaro
Sep 29, 2015 07:07 PM
