the Airbag light wont go off, how can i get it to go off?
Old Feb 12, 2003 | 08:05 PM
903.1fbody's Avatar
subject pretty much says it all, i just got the car from my aunt and i tried to pull the fuse and the light is still on, i dont really care much for an airbag anyway so if there was a way i could just get the light to go off,i'd be fine with that. thanks alot guys
Old Feb 13, 2003 | 10:43 AM
Vader's Avatar
90 3.1,
Welcome Aboard!
I have a fairly comprehensive list of ECM error codes, ABS error codes, and even later PCM codes, but I don't have a lot of data on the early SIR systems.
What I can tell you is that the lamp is used as a diagnostic. When the ignition is first turned on, the SIR system scanns the sensors and loads connected to it. The lamp should flash once for each sensor/load in the system. If the lamp remains on, there is a problem with the control, a sensor, or the firing coil in the steering column, or one of the electrical connections in the system.
Whatever you do, disable the system before you perform any diagnosics or testing. You'll have to disable any radio Theft-Lock codes, then disconnect the battery and wait a few minutes. After that, you should be able to safely inspect electrical connectors, etc. Connectors are usually easily identified since they are molded in a bright yellow plastic. Don't disturb these connections or the wiring while the battery is connected, or you might be shopping for a new steering wheel center pad. Worse yet, an inflating air bag can casue serious injury, especially in these earlier models.
Old Feb 13, 2003 | 12:46 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I solved similar problem in my brother's Jeep Cherokee 1998.
We pulled off the steering wheel.
Problem could be at:
-AirBag connector (yellow) in the steering wheel center (back). Dissasemble with care = put your face off the air bag way, or you will need a pencil for drawing a new face.
-Special wire "coil" (SIR coil) damaged o disconnected caused by front wheels overturned (it was our problem). We welded the 5 wires in this coil and ready! air bag + horn.
-Corroed connection at fuse box (back).
-Fuse failure.
-Bad connection at airbag sensor.
- Others are the wire lines/cables (too low possibility).
Good lucks,
Denis V.
Old Feb 13, 2003 | 01:24 PM
Jza's Avatar
Jza
just pull the bulb
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
