Speed Pro 2V relief pistons?
Old Feb 12, 2003 | 08:46 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I plan on using the Speed Pro hyper. flat top pistons with the 2 valve reliefs to get a 10:1 compression ratio with some 64cc heads. I was wondering if I could run into any piston to valve interfrence with these pistons?
Old Feb 12, 2003 | 08:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
As long as you're careful with the cam lift, use a real mild one and keep it below about .650" or so, it should be fine.
Old Feb 12, 2003 | 09:04 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
The cam I'm using is the 211 cam. So I should be fine then. Thanks
italiano67
Sep 22, 2015 08:42 AM
angel2794
Sep 8, 2015 06:22 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
