oil pump pickup
Old Feb 14, 2003 | 03:02 PM
black83z's Avatar
oil pump pickup
Okay, im getting a lot of different opinions from a lot of different people. I bought a rebuilt motor that came with an oil pump but no pickup. I am also told that the pickup needs to be welded. Where does it need to be welded? To the pump, to the pan, or to the block. I've also been told it doesnt need to be welded, just bolted to a main cap, which doesnt seem to make much sense, but again, i dont know my *** from a whole in the ground. I kinda wanna get this done soon so i can get started this weekend. Thanks for all the help.
Matt
Old Feb 14, 2003 | 03:16 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
oil pump gets bolted to rear main bearing cap.
pickup gets inserted into hole in oil pump.
it's a good idea to tack weld the oil pickup tube to the oil pump when you stick it in.
Old Feb 14, 2003 | 03:37 PM
Vader's Avatar
Black,
Another option is to weld a brace to the oil pickup and bolt it to the oil pump lower cover. The primary idea behind all of this is to prevent the pickup from falling off the pump (it can happen), thereby starving the engine for oil. That usually results in a catastrophy for the engine.
Old Feb 14, 2003 | 04:05 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Or you could get one of these from jegs
Old Feb 14, 2003 | 04:16 PM
black83z's Avatar
e-man, what the hell is that, whats the PN and how much does it cost? This seems to make my life a lot easier then, if its just welding the pickup to the pump, a machine guy said 10 bucks to do it. He said i needed the pan or somethin too so that he could check the depth or something like that. Hey, i dug a hole! No, no, thats my ***, sorry.
Matt
Old Feb 15, 2003 | 07:37 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The PN# 555-23620 and its $8.99
Old Feb 15, 2003 | 02:55 PM
black83z's Avatar
Thats definitely a spiffy little device. A buddy of mine is just going to tack weld it tho. Thank you all for your help.
matt
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
