is this normal?
Car: 1990 RS
Transmission: TH-350
is this normal?
i am still hunting down a bad idle/stumbling prob, and while the car was running i unplugged the tps. the motor idled to about 1100rpm and held steady without missing a beat. is this normal?
Without a TPS, the ECM will enter Backup Fuel and Spark mode. It will presume a fuel rate based on other inputs, like RPM, MAP/MAF sensor readings, and CTS. It is only intended to get you home or to a service center to repair the problem. Predicting how that will affect other problems is nearly impossible, but Backup fuel is normally WAY rich just to keep the engine running.
Linson
Oct 1, 2015 09:50 PM
