Couple more questions on ditching the computer and going to carb...
Old Feb 16, 2003 | 10:55 AM
CamaroX84's Avatar
I am completely ditching my TPI and going to run everything without a computer. I have a few questions though.
-Will the gauges in the dash work without the computer??
-I have a 9.5" ACT 2600 lockup stall converter. Since I am ditching the computer, I will obviously lose the lockup. Will this hold back any power to the rear wheels, or does lockup only affect gas mileage?
Any help would be greatly appreciated. Thanks in advance.
Old Feb 16, 2003 | 11:58 AM
1986redbird's Avatar
I don't think any of the dash gauges read through the computer so they should all still work as long as your carefull on which wires you unhook/cut, as you said the torque converter won't lock up without the computer, this is bad, it creates ALOT of heat in the tranny (BAD), you could always get the kit from summit or jegs that will lock up the converter automaticly or you could wire it with a switch and do it manually.
Old Feb 16, 2003 | 12:01 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yep, guages will work.
The TC will work fine as well, but you have to hook up a pressure switch in the tranny and wire it with power.
Old Feb 16, 2003 | 12:07 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
Is this a good Idea?
http://www.highperformancecars.com/crosley/lockup1.htm
Old Feb 16, 2003 | 12:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Don't cut any wires, no point in sodomizing stuff unnecessarily, remove the harness carefully and keep it for future whatever or sell it to someone that already sodmized theirs.
Get a switch for the TCC.
Old Feb 16, 2003 | 12:48 PM
CamaroX84's Avatar
Well, I don't really want to spend 130 bucks on a lockup control switch. My car originally had an LG4 motor in it. I still have the old computer and harness. Can I just hook up the computer for the sole purpose of controlling the converter? If so, what all do I need to hook up to the harness? Thanks for the replies.
Old Feb 16, 2003 | 12:53 PM
the computer read info. from the carb. (TPS) to determine when to engauge the converter. without the CC-Carb I don't think it will know when to engauge.
Old Feb 16, 2003 | 01:10 PM
CamaroX84's Avatar
I thought that the only thing that determined whether or not the converter locks up was vehicle speed. If this is the case, then it would work because there is a speed sensor on the back of the speedo, and with the dash hooked up to the computer then it should work, right? Thanks.
Old Feb 16, 2003 | 02:07 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
i ditched my computer and threw in a new carbed engine and had no problems.
Old Feb 16, 2003 | 07:18 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Does the lockup and all this apply to a manual tranny too, such as a T5?
Old Feb 16, 2003 | 10:15 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
No, a manual tranny doesn't have a tourque convertor so a lockup switch is not needed.
Old Feb 17, 2003 | 11:39 PM
Marshall89ws6's Avatar
you could run non-lockup but if you do that you want to run a good tranny cooler b/c of all that heat...... but if i were u i would ditch the 700 and go with a th-350.
Cleotiz
Jan 6, 2018 08:56 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
