tunnel ram
Old Feb 17, 2003 | 08:04 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
tunnel ram
i know this will probably slow my car down , but its something i've got to try. i'm goig to be installing a tunnel ram on my car, weiand intake and dual holley 450's- mechanicals. any body running one of these? how far out of the hood do the carbs stick out? i have a 2" cowl hood now.
Old Feb 17, 2003 | 09:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes it will slow your car down. Tunnel rams look good but will start to work above 4000 rpm. You'll also kill your gas mileage.
Your 2" cowl hood will have to go. The tunnel ram should stick both carbs on the outside of the hood.
Lots of luck getting it all hooked up and tuned. Although they look impressive, you're better off running a Victor Junior intake and one large carb.
Old Feb 18, 2003 | 04:26 PM
craig's Avatar
Car: 86 camaro
i guess the look is the appeal.i'm running a victor jr. intake and a 750 double pumper now. the cost of replacing my rearend has got me thinking of other directions to take the car.are the tuning problems with the tunnel ram setup really that bad?
Old Feb 18, 2003 | 04:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They can be pretty tough....
Look at the firing order, that should give you a clue. You have the front 4 cyls firing 2-1-(8)-4-3, and the back 4 firing 8-(4)-(3)-6-5-7. If they drew through the 2 carbs more steadily, with cyls evenly spaced throughout the order, it would be alot easier. But they aren't so you end up with fuel pooling out, different cyls that run way richer or leaner than others, etc. The ones that have no plenum (each runner goes to its own carb venturi) are generally easier to tune but require special carbs, with the "secondaries" being the same as primaries; you end up essentially with 8 carbs made into 2 castings with 4 fuel bowls.
Linson
Oct 24, 2025 02:00 PM
cowansauto
Apr 3, 2025 12:51 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
