Help with pulleys!!
Old Feb 19, 2003 | 08:51 PM
zzghy's Avatar
Help with pulleys!!
Im not sure what year block I have. And the problem is that I put my old v-belt set up on the new block. But the alt, and power steering only has one bolt holding them on!! So the question is if this block that I got was origanally a serpentine setup is it possible to put v-belts on? Are they interchangeable . Cause im have all kinds of problems!!! And no I dont have any of the pulleys with the new block , just got the block. Where would I look for numbers to find out what I'v got here?
Old Feb 19, 2003 | 09:40 PM
zzghy's Avatar
any help here????
Old Feb 19, 2003 | 09:49 PM
rezinn's Avatar
If you only changed the block, you shouldn't have any problems at all. The accessory bolt holes are in the heads. The bolt holes for both systems should be identical, anyway.
Old Feb 19, 2003 | 09:56 PM
zzghy's Avatar
I have dart pro 1 heads aluminum . dont know what the deal is but if it was origianally a serpentine block wouldnt things be on opposite side?
Old Feb 20, 2003 | 06:44 PM
zzghy's Avatar
got my casting numbers today and found out that I have and 80-85 350. Did any 350s come with serpentines between 80 and 85?
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
